G
我得到的错误
, 而安装下载的源..
输出功率和载列如下: -
人工神经网络(在)anndesktop:〜$
光碟/首页/安/桌面/
人工神经网络(在)anndesktop:〜/
桌面$储蓄
bttv0.9.15
epson31411eu.zip motion3.2.9。
tar.gz
bttv0.9.15。
tar.tar epson31411eu.zip_FILES
桌面$焦油xvzf
/ home/ann/desktop/motion3.2.9。
tar.gz
motion3.2.9 /
motion3.2.9 /
motion.spec.in
motion3.2.9 /
picture.h
motion3.2.9 /
rotate.h
motion3.2.9 /
pwcioctl。
hpwc9.0.1
motion3.2.9 /
alg.h
motion3.2.9 /
conf.c
motion3.2.9 /
pwcioctl。
hpwc8.0
motion3.2.9 /
CODE_STANDARD
motion3.2.9 /
README.MacOSX
motion3.2.9 /
thread2.conf
motion3.2.9 /
motion.initFreeBSD。
sh.in
motion3.2.9 /
自述
motion3.2.9 /
netcam_wget.c
motion3.2.9 /
常见问题
motion3.2.9 /
webhttpd.h
motion3.2.9 /
webcam.h
motion3.2.9 /
motiondist。
机密
motion3.2.9 /
的INSTALL
motion3.2.9 /
ffmpeg0.4.8macosx。
补丁
motion3.2.9 /
picture.c
motion3.2.9 /
event.h
motion3.2.9 /
ffmpeg.c
motion3.2.9 /
netcam_wget.h
motion3.2.9 /
draw.c
motion3.2.9 /
track.h
motion3.2.9 /
mmx.h
motion3.2.9 /
conf.h
motion3.2.9 /
motion.1
motion3.2.9 /
video2.c
motion3.2.9 /
README.axis_2100
motion3.2.9 /
netcam_ftp.h
motion3.2.9 /
信贷
motion3.2.9 /
configure.in
motion3.2.9 /
thread4.conf
motion3.2.9 /
pwcioctl。
ħ
motion3.2.9 /
pwcioctl。
h10.0.5
motion3.2.9 /
video_common.c
motion3.2.9 /
motion.h
motion3.2.9 /
netcam_ftp.c
motion3.2.9 /
rotate.c
motion3.2.9 /
netcam.c
motion3.2.9 /
video_freebsd.h
motion3.2.9 /
netcam_jpeg.c
motion3.2.9 /
README.FreeBSD
motion3.2.9 /
Makefile.in
motion3.2.9 /
video.h
motion3.2.9 /
event.c
motion3.2.9 /
ffmpeg.h
motion3.2.9 /
video.c
motion3.2.9 /
motion.c
motion3.2.9 /
motion.initRH。
在
motion3.2.9 /
更新日志
motion3.2.9 /
webhttpd.c
motion3.2.9 /
复制
motion3.2.9 /
webcam.c
motion3.2.9 /
thread1.conf
motion3.2.9 /
video_freebsd.c
motion3.2.9 /
alg.c
motion3.2.9 /
thread3.conf
motion3.2.9 /
motion_guide.html
motion3.2.9 /
motion.initDebian。
在
motion3.2.9 /
track.c
motion3.2.9 /
配置
motion3.2.9 /
motion.spec
motion3.2.9 /
netcam.h
桌面$法律公告š
motion3.2.9
议案
桌面$光盘议案
台式机/议案$。/配置
检查达尔文...否
检查的* BSD的...否
检查海合会...海湾合作委员会
检查C编译器默认的输出文件的名称...a.out的
检查是否有C编译器工程...是
检查我们是否交叉编译...否
检查的可执行文件后缀...
检查的对象文件后缀...Ø
检查是否使用的是GNU C编译器...是
海湾合作委员会检查是否接受湾..
是
检查海合会选择接受标准C89 ...没有必要
检查中lpthread pthread_create ...
是
检查libjpegmmx ...
跳绳
检查的jpeg_set_defaults在ljpeg ...
否
您没有安装的libjpeg
检查如何运行C预...海湾合作委员会的位置
检查来处理grep的排长和E. ..
/斌/消灭牛瘟
检查egrep的.../本/消灭牛瘟首页
检查的ANSI C头文件...是
检查为SYS / types.h ...是
检查为SYS / stat.h ...是
检查stdlib.h ...是
检查string.h中...是
检查memory.h ...是
检查strings.h ...是
检查inttypes.h ...是
检查stdint.h ...是
检查unistd.h中...是
检查用mjpegtools / jpegutils.h可用性...否
检查用mjpegtools / jpegutils.h存在...否
检查用mjpegtools / jpegutils.h ...否
检查用mjpegtools / mjpeg_types.h可用性...否
检查用mjpegtools / mjpeg_types.h存在...否
检查用mjpegtools / mjpeg_types.h ...否
检查用mjpegtools ...否
检查自动检测FFmpeg中...未找到
* libavcodec.a或libavcodec.so或*
* libavformat.a或libavformat.so未找到:*
*所有FFmpeg的特点禁用*
*请阅读帮助运动指南:*
* http://motion.sourceforge.net *
检查MySQL支持...测试
检查autodect MySQL的头...未找到
无效的mysql目录
无法找到mysql.h。
检查PostgreSQL的...找不到libpqfe。
每小时请指定安装路径的PostgreSQL
检查的ANSI C头文件...(缓存)是
检查stdio.h中的可用性...是
检查stdio.h中存在...是
检查stdio.h中...是
检查unistd.h中...(缓存)是
检查fcntl.h可用性...是
检查fcntl.h存在...是
检查fcntl.h ...是
检查time.h可用性...是
检查time.h存在...是
为time.h.检查..是
检查signal.h中可用性...是
检查signal.h中存在...是
检查signal.h中...是
检查sys / ioctl.h可用性...是
检查sys / ioctl.h存在...是
检查为SYS / ioctl.h ...是
检查sys / mman.h可用性...是
检查sys / mman.h存在...是
检查为SYS / mman.h ...是
检查的Linux / videodev.h可用性...是
检查的Linux / videodev.h存在...是
检查用于Linux / videodev.h ...是
检查sys / param.h可用性...是
检查sys / param.h存在...是
检查为SYS / param.h ...是
检查结构v4l2_buffer ...是
检查V42L支持...是
检查短整型...是
检查的短整型大小...2
检查廉政...是
检查int的大小...4
检查一个ANSI Cconforming
const ...是
检测处理器:英特尔(R)酷睿(TM)2 Duo处理器E6550@2.33GHz
CPU的优化:3月=
i686
检查bswap指令...是
配置:创建。/ config.status的
config.status的:创造motion.initFreeBSD。
上海
config.status的:创建motion.initDebian
config.status的:创建motion.initRH
config.status的:创建motion.spec
config.status的:创建Makefile文件
*配置状态*
操作系统:Linux
pthread的支持:是
JPEG文件格式支持:无
**致命错误您必须有JPEG支持***
MJPEG编码支持:无
用V4L包括:是
的V4L2支持:是
FFmpeg的支持:无
MySQL支持:无
PostgreSQL的支持:无
CFLAGS:克
氧气
DMOTION_
的V4L2 DTYPE_
32 =“整数”DHAVE_
BSWAP 3月=
i686
林达:流明
lpthread
LDFLAGS:
安装前缀:/ usr /本地
台式机/议案$使清洁
欢迎来到运动安装过程的动态检测守护!如果你
在此过程中的错误信息,请报告他们的邮件列表。那个
运动指南中包含的所有信息
, 你应该需要得到运动启动和运行。
运行“作出updateguide”下载议案的指南的最新版本。
版本:3.2.9
平台:Linux(如果这是不正确的,请阅读README.FreeBSD)
删除编译的文件和二进制文件...
台式机/运动$使
运动指南中包含的所有信息
, 你应该需要得到运动启动和运行。
版本:3.2.9
产生依赖性,请稍候...
在文件中包括来自motion.h:247,
从motion.c:10:
netcam.h:18:21:错误:jpeglib.h:没有那个文件或目录
从conf.c:26:
从draw.c:13:
从video.c:12:
从video2.c:68:
从video_common.c:12:
从netcam.c:40:
从netcam_ftp.c:11:
从netcam_jpeg.c:15:
netcam_jpeg.c:21:20:错误:jerror.h:没有那个文件或目录
从netcam_wget.c:26:
从track.c:11:
从alg.c:9:
从event.c:13:
从picture.h:13,
从picture.c:11:
picture.c:15:20:错误:jerror.h:没有那个文件或目录
从rotate.h:14,
从rotate.c:32:
从webhttpd.c:13:
从picture.h:13,
从webcam.c:21:
使:*** [。依靠]错误1
台式机/议案$使安装
安装文件...
mkdir
p
/ usr / local / bin目录
mkdir p
/ usr/local/share/man/man1
mkdir:无法创建目录`/ usr/local/share/man/man1':权限被拒绝
使:*** [安装]错误1
台式机/运动$
, 而安装下载的源..
输出功率和载列如下: -
光碟/首页/安/桌面/
桌面$储蓄
bttv0.9.15
tar.gz
bttv0.9.15。
桌面$焦油xvzf
tar.gz
motion3.2.9 /
motion3.2.9 /
motion.spec.in
motion3.2.9 /
picture.h
motion3.2.9 /
rotate.h
motion3.2.9 /
pwcioctl。
hpwc9.0.1
motion3.2.9 /
alg.h
motion3.2.9 /
conf.c
motion3.2.9 /
pwcioctl。
hpwc8.0
motion3.2.9 /
CODE_STANDARD
motion3.2.9 /
README.MacOSX
motion3.2.9 /
thread2.conf
motion3.2.9 /
motion.initFreeBSD。
sh.in
motion3.2.9 /
自述
motion3.2.9 /
netcam_wget.c
motion3.2.9 /
常见问题
motion3.2.9 /
webhttpd.h
motion3.2.9 /
webcam.h
motion3.2.9 /
motiondist。
机密
motion3.2.9 /
的INSTALL
motion3.2.9 /
ffmpeg0.4.8macosx。
补丁
motion3.2.9 /
picture.c
motion3.2.9 /
event.h
motion3.2.9 /
ffmpeg.c
motion3.2.9 /
netcam_wget.h
motion3.2.9 /
draw.c
motion3.2.9 /
track.h
motion3.2.9 /
mmx.h
motion3.2.9 /
conf.h
motion3.2.9 /
motion.1
motion3.2.9 /
video2.c
motion3.2.9 /
README.axis_2100
motion3.2.9 /
netcam_ftp.h
motion3.2.9 /
信贷
motion3.2.9 /
configure.in
motion3.2.9 /
thread4.conf
motion3.2.9 /
pwcioctl。
ħ
motion3.2.9 /
pwcioctl。
h10.0.5
motion3.2.9 /
video_common.c
motion3.2.9 /
motion.h
motion3.2.9 /
netcam_ftp.c
motion3.2.9 /
rotate.c
motion3.2.9 /
netcam.c
motion3.2.9 /
video_freebsd.h
motion3.2.9 /
netcam_jpeg.c
motion3.2.9 /
README.FreeBSD
motion3.2.9 /
Makefile.in
motion3.2.9 /
video.h
motion3.2.9 /
event.c
motion3.2.9 /
ffmpeg.h
motion3.2.9 /
video.c
motion3.2.9 /
motion.c
motion3.2.9 /
motion.initRH。
在
motion3.2.9 /
更新日志
motion3.2.9 /
webhttpd.c
motion3.2.9 /
复制
motion3.2.9 /
webcam.c
motion3.2.9 /
thread1.conf
motion3.2.9 /
video_freebsd.c
motion3.2.9 /
alg.c
motion3.2.9 /
thread3.conf
motion3.2.9 /
motion_guide.html
motion3.2.9 /
motion.initDebian。
在
motion3.2.9 /
track.c
motion3.2.9 /
配置
motion3.2.9 /
motion.spec
motion3.2.9 /
netcam.h
桌面$法律公告š
motion3.2.9
议案
桌面$光盘议案
台式机/议案$。/配置
检查达尔文...否
检查的* BSD的...否
检查海合会...海湾合作委员会
检查是否有C编译器工程...是
检查我们是否交叉编译...否
检查的可执行文件后缀...
检查的对象文件后缀...Ø
海湾合作委员会检查是否接受湾..
是
是
检查libjpegmmx ...
跳绳
否
您没有安装的libjpeg
检查来处理grep的排长和E. ..
/斌/消灭牛瘟
检查的ANSI C头文件...是
检查stdlib.h ...是
检查string.h中...是
检查memory.h ...是
检查strings.h ...是
检查inttypes.h ...是
检查stdint.h ...是
检查unistd.h中...是
检查用mjpegtools ...否
检查自动检测FFmpeg中...未找到
*所有FFmpeg的特点禁用*
*请阅读帮助运动指南:*
检查MySQL支持...测试
无效的mysql目录
无法找到mysql.h。
检查stdio.h中的可用性...是
检查stdio.h中存在...是
检查stdio.h中...是
检查unistd.h中...(缓存)是
检查fcntl.h可用性...是
检查fcntl.h存在...是
检查fcntl.h ...是
检查time.h可用性...是
检查time.h存在...是
为time.h.检查..是
检查signal.h中可用性...是
检查signal.h中存在...是
检查signal.h中...是
检查V42L支持...是
检查短整型...是
检查的短整型大小...2
检查廉政...是
检查int的大小...4
const ...是
CPU的优化:3月=
i686
检查bswap指令...是
上海
*配置状态*
操作系统:Linux
pthread的支持:是
JPEG文件格式支持:无
**致命错误您必须有JPEG支持***
MJPEG编码支持:无
用V4L包括:是
的V4L2支持:是
FFmpeg的支持:无
MySQL支持:无
PostgreSQL的支持:无
CFLAGS:克
氧气
DMOTION_
的V4L2 DTYPE_
32 =“整数”DHAVE_
BSWAP 3月=
i686
林达:流明
lpthread
LDFLAGS:
安装前缀:/ usr /本地
台式机/议案$使清洁
运动指南中包含的所有信息
, 你应该需要得到运动启动和运行。
版本:3.2.9
删除编译的文件和二进制文件...
台式机/运动$使
运动指南中包含的所有信息
, 你应该需要得到运动启动和运行。
版本:3.2.9
产生依赖性,请稍候...
从motion.c:10:
从conf.c:26:
从draw.c:13:
从video.c:12:
从video2.c:68:
从video_common.c:12:
从netcam.c:40:
从netcam_ftp.c:11:
从netcam_jpeg.c:15:
从netcam_wget.c:26:
从track.c:11:
从alg.c:9:
从event.c:13:
从picture.h:13,
从picture.c:11:
从rotate.h:14,
从rotate.c:32:
从webhttpd.c:13:
从picture.h:13,
从webcam.c:21:
使:*** [。依靠]错误1
台式机/议案$使安装
安装文件...
mkdir
p
mkdir p
使:*** [安装]错误1
台式机/运动$
