M
myown
代码:#包括的“D:\ 4431.h”#字节QEICON = 0xFB6
#字节POSCNTH = 0xF67 / /捕获2册,高字节/ QEI位置计数器寄存器,高字节
#字节POSCNTL = 0xF66 / /捕获2册,低字节/ QEI位置计数器寄存器,低字节
#字节MAXCNTH = 0xF65 / /捕获3册,高字节/ QEI最大。
数限制注册,高字节
#字节MAXCNTL = 0xF64 / /捕获3册,低字节/ QEI最大。
数限制注册,低字节
#字节ANSEL0 = 0xFB8 / /
#位ANS2 = ANSEL0.2
#位ANS3 = ANSEL0.3
#位ANS4 = ANSEL0.4#包括“QEI.h”#字节PWMCON0 = 0xF6F / / PWM控制寄存器0
#字节PTCON0 = 0XF7F / / PWM定时器控制寄存器0
#字节PTCON1 = 0XF7E / / PWM定时器控制寄存器0
#字节PTPERH = 0xF7A / / PWM周期寄存器
#字节PTPERL = 0xF7B / / PWM周期寄存器#使用fast_io(甲)
#使用fast_io(乙)
#使用fast_io(丙)#字节门= 0xF80
#PORTB的字节= 0xF81
#字节PORTC = 0xF82#位RB0上= PORTB.0
#位RB1赛车= PORTB.1/ /连接到液晶显示器(发那科3000)#位DD1 = PORTC.0 / /的XA(1)1
#位DD2型= PORTC.1 / /的XA(1)2
#位DD4 = PORTC.2 / /的XA(1)3
#位DD8 = PORTC.3 / /的XA(1)4
#位载重吨= PORTC.4 / /的XA(1)5静态符号int32 currentQEIPos,温度; / /必须签名,因为算术长。#包括的“D:\ f3000.h”#int_rtcc
无效clock_isr()/ /发光二极管显示,从3000法努克
select_axis(十);
data_output(currentQEIPos);
)无效的main()
set_tris_a(0xff);
set_tris_b(0b00111100);
set_tris_c(0);
set_tris_d(0xff);
set_tris_e(0xff);
setup_adc_ports(NO_ANALOGS | VSS_VDD);
setup_adc(ADC_OFF | ADC_TAD_MUL_0 | ADC_WHEN_INT0 | ADC_INT_EVERY_OTHER);
setup_spi(假);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);setup_power_pwm_pins(PWM_COMPLEMENTARY,PWM_OFF,PWM_OFF,PWM_OFF);
/ / PPWM声道0和1两种相反的价值观,始终
setup_power_pwm(PWM_CLOCK_DIV_4 | PWM_FREE_RUN,1,0,1023,0,1,0);
/ /添加死无功负荷时间
enable_interrupts(INT_RTCC);
enable_interrupts(全球);
/ / setup_oscillator(假);initQEI(4);而(真)
currentQEIPos = getQEIPos();
set_power_pwm0_duty(2048);
数限制注册,高字节
数限制注册,低字节
#位ANS2 = ANSEL0.2
#位ANS3 = ANSEL0.3
#使用fast_io(乙)
#PORTB的字节= 0xF81
select_axis(十);
)无效的main()
set_tris_a(0xff);
set_tris_c(0);
set_tris_d(0xff);
set_tris_e(0xff);
setup_spi(假);
setup_wdt(WDT_OFF);
/ /添加死无功负荷时间
